Danfoss VLT Micro FC51
chud
Oct 2007
KALAHARI
1,123
Hi Guys
Took over a job where the customer has VLTmicro fc51 drives. Im installing a plc to control them so I would need a digital input from them telling me if they are tripped. I have never used these drives before
There is no relay outputs on these drives. The only thing I found in the manual is that you can switch the analog output to a digital output via paramater 6-90 and 6-92. I have done this but still dont get the contact to react. Just get a permanent 18Vdc out.
Is there any other settings you guys know of?
Thanks for any advice
Your PLC input likely presents insufficient load for that solid state (converted) output, your PLC input is reading the leakage current regardless of the state. You may need to experiment with burden resistors or at the very worst, use the VFD output to drive an interposing relay and the relay to give you the input to the PLC.
most VFD have relay output for VFD status
He makes a good point. I took it at your word that you said this drive has no output other than the convertible one, but I just looked at the manual and there is indeed a relay output. 01, 02 and 03 terminals are a Form C relay. 03 is common, 01 is NO and 02 is NC. The functionality is programmed in 5-40.
RTFM...
Hello everyone, I am an engineering student who took on a project to design and build a control system for an industrial coffee roaster as my...
4,506
Hello all. I am hoping someone here has installed a Danfoss VLT Midi FC 280 and connected an encoder to it. I am just trying to make sure I select...
464
Having a small problem with a new danfoss micro VLT FC51 drive I was hoping someone on here could help with. my setup: my motor speed is...
1,419
Hi all, Got a Danfoss FC102 VLT drive which reverts to Off mode whenever I cycle power to it. I'm controlling it over ethernet from a Control...
1,834
Hi all, I am having a problem with 3 VLT 2800 drivers. All are showing on occasion error 16. I know that this points to short circuit on the...
2,295
