Data exchange between S7-300 PLC's
userxyz
May 2002
any
2,768
I have 3 machines that can work stand-alone, @ the end of each segment (each machine) MPI network,there is a repeater connected locally.
Upstairs we have an MP270B panel, it's segment is connected to 3 repeaters locally, after each repeater there is a connection to the repeaters in the machines. The MP270B is ment to control data, with change connection functionallity we can connect from there to a machine, A B or C.
Is u have autocad, then u can see how the network is. Harder to explain then is is.
So, my question is, how can I send an Integer from 0ne machine to the other one when both are connected ?
So, I'll ask it more simple:
I have 2 PLC's on an MPI network, on has adres 2 and the other one 4, how can I send from one plc to the other one ?
Hello Combo;
Maybe this can give you a first answer:
Or you could use Global Data exchanges (configured in Netpro) if the amount of data is small and is always the same. It is very easy to setup and runs in the background.
Hope this helps,
Daniel Chartier
Gents, I've a Beckhoff TwinSAFE project in TwinCAT 3 where I've 2 EL6910 Safety controllers, and need to exchange data between them. So I...
855
Hi everyone, I'm currently finding ways to create variable that can be read & write between 2 Beckhoff controllers. Target to be achieved: 1) PLC...
2,322
Hello. I am trying to do some basic file operations (move file from one folder to another, rename file in the new folder etc) and usually I just...
2,198
I'm looking to exchange approx 50kb of data between an S7-1500 and a Melsec Q Series PLC. Has anyone ever done this? Is it even possible given...
1,625
Hi there, Can anyone suggest the solution to communicate between AB Compactlogix L36ERM controller(Which is having remote flex IOs over ethernet)...
3,705
