Data log
davidvu
Apr 2015
CA
19
Is there a way to data log more than 1,000,000 points? I'm using ftv 8 with pv+ 1500. Also, If data log trigger is set to periodic at 1 second, then i would have 2 points every second if I'm logging two registers?
No, you cannot log more points. You can create as many data log models as you want, but only 1 can run in a project.
Yes, that is the max points for the total of all your registers/tags.
You can look at the data log as a historical trend. It's the only way to see the data on the PV+.
If you want to log data to a text file (CSV) then use the Datastore ActiveX control. That only has a limit on the storage space, but will NOT work with the trend display.
I wish they would just add all the features of the Datastore ActiveX into the Data Log models.
Thanks for the info. Datalog plus is a great solution. Is there a way to programmatically confirm/indicate that the datalog plus active x is active logging data?
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
259
We are using RED LION HMI Since las 15 years. To day we have found that My log file has data up to 22 Mar 2024 1:16. Then After new Log File is...
23
1,480
Hi , i currently have data logs running but i need a way to link a tag to them so if there ever not running i can trigger an alarm? what is the...
1,845
Hi all, I am working on a project in Tia Portal v17, and I have a function block that is responsible for data logging. This data log begins once...
1,803
I am stuck on something, and would appreciate if someone might have a suggestion to help me. I need to automatically email CSV log data from...
1,792
