Data Logging
Feb 2003
Oxfordshire
37
All,
I need to log about 20 data values from within a Siemens 315-2 DP over industrial ethernet. I already have a pc for the task I just need the software etc so that I can capture the data. Does anyone know of anything that I can use...
My budget is about £500... (I have gone way over budget on my project)
Kind Regards
Barry Humphries
Barry, what is the Interwall for Your data.
InTouch with 64 Tag-licence and dumping to Text.txt file
What is you data variables ?. Bool, Integer, String etc.
This is for InTouch (also .csv file format have supported)
DIM Ht as Message;
Ht = StringChar(9); {HorTab}
{Data1 is real, data2 is integer, data3 is Message....}
MsgeTag = text(data1,"#.##") + Ht + text(data2,"#")+ Ht + data3....
...+ data20};
FileWriteMessage("C:\LOG\Text.txt",-1,MsgeTag,1);
Also is possible use MS-Access or MS-SQLServer from InTouch
but you don't need them.
Seppo,
I have not got a scada system with this particular plc, I want to directly pick the data from the plc and log it.
The variables are real numbers, mostly being pressure, flow, temperature, current etc. I have developed some PID loops that I need to make sure that they are actually doing what they are meant to do!
The logging is also going to be used for reducing wasted compressed air etc.
I quite like the idea of using visual basic but have no experience with it. A few pointers would be useful!
Barry, that Scada is in you budget I think.
I'm working with same conf., but I'm using InTouch for dataBase.
As well I can do it with VB, but it has done what has done. My 315-2DB plc with CP341 are in the ship and I can't test it with VB anymore.
Start from SIMATIC NET -> OPC Server -> readme.wri, there are some starting information and more can be in help files and internet.
http://www.ad.siemens.de/industrial-ethernet/index_76.htm.
I'd tryed VB with STData-control to Form as in readme.wri file and it runs, but as. say, I dont have Hardware here. Perhaps someone can help more. br. Seppo
Barry,
I am assuming you don't need to do this for a long period of time, just long enough to test out you program and what not.
If that is the case this is what I would do. You can download a OPC server and client which will run for 2 hours at a time. You can write whatever data you want to an excel speadsheet or an Access Database. I have used the server from www.kepware.com and a client from www.matrikon.com.
I looked at the Kepware site and they have Siemens servers but I don't know Siemens systems so you would have to see if they have one for the system you are running.
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
67
Hi, Wy we log data in PLC using DLG instruction, when we have option to log data in HMI
80
Hi everyone id like to start by saying im not a PLC programmer so my technical terminology is limited. i would like advice on what software is...
297
Hi All, I am looking for recommendations for a data logging software package that can be used for a simple 1 PLC installation. The installation...
1,383
Hello all, I am working on a DA70A flex edge data logger. I am it communicating with a computer on the network. I can ping it and everything looks...
391
