Data style troubles
PLC Pie Guy
Jun 2013
Halifax
1,144
Hey All.
I'm working on an IFM Vision system. Its interfaced with an L45 and seems to do well. However, if you look at the screen shot you will see what my trouble is. The sensor is always sending me back 2 HEX values as SINT data types. The CPT instruction in the image works, 60% of the time. If you notice in the image, the value of [14] is "bd", which should be = 189. So why does my CPT instruction end up negative 66 if [15] = 0 and [14] = 189. it should be simply 189 since its multiplying [15] by 0. Normally that is the case, but every few minutes this value will do something like you see on the screen and end up with -66 or something else that does not equal what I have as an expression in the CPT instruction........ I'm totally lost on how it comes up with this value.... The works thing is, this works, and its accurate, then its wacky, then it works again.
Help please!!!
So, the longest RA Tech call Iv ever had just ended with no success. Two of their heads on this all afternoon and still stuck. They want to try again tomorrow. They tried a few things with Byte swaps and such but no love. IFM...... No thanks from the absolute 0 support I received today from IFM (n)(n)(n)(n)(n) to you.
The HEX Value "bd" = -67 because it is a signed integer value. The 8th bit is true which makes it negative.
If you use the BTD instruction To copy the bit pattern to and INT then you'll get 189. This will allow you to use all 8 bits without the signed bit.
You can do this in one step, too, and write directly to your INT tag by setting the Dest Bit in the left BTD instruction to "8" rather than "0".
I use this method frequently when sending Group IO to a Fanuc Robot. The Fanuc I/O registers in the PLC are all defined as SINTs so, in order to send an INT value to the robot, use two BTD instructions to do it.
Steve,
I have used the same method to swap bytes but in this case that would not give you the correct value. The first value needs to be multiplied by 256 then add the 2nd value to get a total. Then convert that total to a Real. The compute instruction is used to apply an offset need for the device. (1st value *256 + 2nd value) To convert to real I would have used the DIV by 1000 and store results in a Real Tag. (0.189) I believe this is the intended result the OP was looking for. The Manufacturer recommended changing values coming from the device to strings and CONCAT to get results then STOR instruction. (string to real) I believe he went that route instead.
http://www.plctalk.net/qanda/showthread.php?t=113068
cwal61 - I believe the BTD method I describe works exactly the same as your method describes and will give the correct value. If I'm wrong, I would appreciate an example.
My apologies, I overlooked the fact that the 8th bit is 256. So I stand corrected.
Hi guys have only just been getting stuck into learning about PLC’s. I’ve got an older version of Studio 5000 and a CompactLogix PLC. I have...
487
I have recovered 4 data carts for a PLC-2. The program that I have is pretty much useless (Ladder only no descriptors 712 rungs) THANKS JOHN...
4,052
Hi everyone, I have a 505 workshop program with PLC type of 555- 1106 and I was wondering how can I download the data documentation window as a...
53
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
62
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
79
