Data type & Addressing an IO Device
Sina R
Oct 2010
Tehran
Hi every body,
I having problem with tag addressing to an IO Device(specially, SIMATIC S7-300, WITH S7NT300 PROTOCOL) in CitectSCADA. My Project tags are imported correct from a data source file in CSV format to CitectSCADA. Well, some tags are digital. So, data type must be digital for those. for example I specified a digital tag as below:
TAG NAME: ST1_DP_1_STR
IO DEVICE: IODev
CLUSTER: FireWaterPumpStation
DATA TYPE: DIGITAL
ADDRESS: D1
During the compile project, i receive sevral errors that says, bad IO Device Variable occured.
Whould you please, help me?:confused:
Hi again,
I found it :)
See the Bin folder; my path was:
C:\Program Files\Citect\CitectSCADA V7.10\Bin\S7NT Driver Help
Hi, I am facing invalid data type when i compile SCL and no luck in finding any old threads? could point me out to right direction? Thanks...
2,185
Hi, Im new to SCL, but decided to start learning it - if only to be able to do some simple jobs such as indirect addressing. got some simple...
6,904
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
280
Hi guys, I have no experience when working with AllenBradley PLC, but I hope someone could clarify the result of multiplication shown in the...
2,216
