Datalink Gateway GW1000
jcreid
Feb 2010
Santa Maria, CA
17
I purchased one of these as recommended by one of our integrators. I am trying to get our A-B PLC5/30A onto an ethernet backbone and have it communicate to our InTouch HMI.
I've been moderately successful so far. The GW1000 now has the correct IP address and it's tied into the DH+ on the PLC.
When I fire up RSLinx, I can see the gateway and I can see the processor at DH+ node address 0.
Where I'm having a problem is how to get InTouch's I/O Server to see the PLC. There is some info about connecting the DASABCIP module to a PLC5, but that assumes you are using an A-B ethernet card in the backplane. The GW-1000 is a standalone unit. Ethernet comes in on one end and DH+ comes out the other.
There is also some info about using ABTCP(the older version), but all the references are to versions of OS(I'm on Server 2003) and InTouch(10) a lot older than mine.
I'm a bit of a newbie at this, so if I've left out something important, let me know and I'll try to get that info.
Thanks!
-Jim
Hi! I am using ifix first time and looking backup scada to learn things. For Datalink I am using following tag reference and it is working fine...
2,425
So, I am trying to enable automatic device configuration (ADC) on my powerflex 753. I learned that in order to do this it requires changing out...
4,551
Hello I'm using PLC5 RSlogix. I have a word showing up at I:146 of my discrete inputs. It should be Rack 14 Group 2. Not sure where this...
1,556
I have a problem when I use RSLogix5000 to read value from PowerFlex 700s by datalink. The returned value is not same with the value on PowerFlex...
3,404
hi everyone! I have a problem when I use RSLogix5000 to read value from PowerFlex 700s by datalink. The returned value is not same with the value...
2,525
