Datalogic barcodescanner => Siemens S7 SERIAL
Jeroen Benoot
Oct 2006
Oostkamp [BE]
42
Hi guys,
I am having some trouble at the moment setting up a serial connection between a Datalogic Powerscan D8330 barcodescanner and a Siemens S7 315 CPU with a CP340 card.
PLC configuration is a 315 with two CP340 cards, one I use for the barcodescanner, and the other I will use for connection with a PC.
I have set the correct baud rate etc in the hardwareconfig.
Even when I connect the scanner to my PC and use software to scan the Com-port I get nothing.
Any ideas where to begin?
Best regards,
Jeroen
Hi All I have a project where I need to scan some barcodes with this Matrix 220 sensor via profinet. CPU 1517F-3, using TIA v17 I was looking...
666
Good Afternoon , We have a few Datalogic Laser Sentinal Scanners . We have 2 that are pointing upward toward the ceiling . Roughly , within...
1,057
I have a datalogic MXE80 vision processor using VPM I am trying to figure out how to get a string of the integer generated by the Discrete input...
1,362
Hello All, I was wondering if anyone had any luck with setting up ethernet/ip connection between Productivity and Datalogic Vlase laser?? Any...
1,476
Is anyone familiar with Datalogics IMPACT software for their inspection cameras? I’m using a P series camera that I programmed to detect defects...
1,075
