Dataman 8700 and Micro800 communication
arvind_g
Sep 2021
Delhi
Hello all..
I am presently working with a Cognex Dataman dm8700dx-e (ethernet) scanner and need to make it communicate (read data from) with a AB Micro850 Plc. Have spent couple of days looking for a way to read scanned data from the scanner into the PLC; but no success yet. Please share any information / thoughts / insights if this can be done and how to if it is possible.
I could get the same scanner work with compactlogix pretty easily but am stuck with the Micro 850 and CCW.
Any help is much appreciated and thanks in advance for the same.
Arvind G
drbitboy,
There is nothing to post for logix5000, I just added it as an Ethernet module to the io configuration and it's working with the compactlogix after little tweaks in the dataman software. Is it that I will need to use CIP generic / symbolic messaging in CCW to make it talk with Micro 850 ?
Thanks,
Arvind G
Try using messaging to the Assembly objects' buffers. CIP Get/Set Attribute Single. Class 4, Instance==assembly #, Attribute 3.
Pturmel,
can you please elaborate a little more , I need a little more guidance as I have not done the messaging before.
Sorry for my incompetence.
Thanks,
ArvindG
pturmel,
thanks for the pointers, I will certainly look into the CCW project and post my findings.
Thanks again,
ArvindG
dataman 8700 and micro 800
I finally did complete the task by communicating the dataman with compactlogix plc and messaging from compactlogix to micro 800. I know, this was not the way I wanted it, but I found it a lot easier and the system works fine in the field for last 4 months.
Just wanted to close the thread, Thanks.
:shoot: Hi, I am looking for a little bit of help : I have Cognex DM 280 barcode reader connected through ethernet to CompactLogix 5380 and...
2,457
Has anyone every attempted to run a Dataman Scanner through a 1783-NATR to take a local network to your enterprise network? I have the NAT...
18
3,020
Hey guys, I have an older Cognex Dataman scanner that i have added to a machine. I have established comms over ethernet. I am able to trigger...
1,783
I am planning on working with a cognex scanner 370 series using a beckhoff PLC and Ethernet/IP protocol. My question is does anyone know if the...
1,252
I've exhausted my resources on this one. My customer has thrown 3 Cognex Dataman 262 scanners at me to configure for a project using RSLogix...
4,312
