Datastore Plus
mel_w
Sep 2006
yorkshire
55
Hi Guys
I am a bit rusty with factorytalk view studio use mainly siemens
what I am trying to do is save a start time to a tag (either internal on PVP or from compactlogix tag) then on a trigger log this to a file using datastore Plus active X
this is part of a batch log where the customer needs the start and end time of a batch recording I would write the log at the end of the batch
Factory talk view ME and PVP 1200
can any one point me in the right direction ?
Regards
Mel
If your using FTVME 10 or higher there is no need to create the macro's to control the Remote display tag. The newer versions allow you to select multiple start screens.
You still need to setup the datastore screen the same with position= -400 x -400 and On top cannot be replaced option.
I have come to the conclusion that ME datastore plus is not very reliable at doing what it is supposed to do. Please prove me wrong so that I can...
2,328
i have 4 tags that i am collecting data on in a log file. is there a formatting available to put each tag in a separate column instead of having...
1,391
i need help in getting Datastor plus to create the log file in the location as configure the activex object. i have an existing project that i...
3,114
I have set up datastore plus, as per https://theautomationblog.com/datastore-plus-step-by-step-setup-in-factorytalk-viewstudio/ Using a PVP 7...
1,667
So I am having a problem collecting data from my PVP7, I am currently testing via two ways of fie collection. I am both using an physical USB, and...
1,373
