DC brushless motor
Farid
Jul 2004
UAE
79
hi to all,
can any body make things clearer for me,
no we have dc brushless motor with the following parameters:
E = 180
T = 23.4
I = 3.3 <---- isnt this supposed to be 6.12 according to ohms law ??
P = 1.1 kw
now , can any body point me to the right direction, what I am doing wrong,
I am calculating the current(I) as follow:
R = E^2 / P
I = E / R
is this the right formula ??
cause I am using it and getting value other than the one mentioned on the motor's name plate.
any help would be appreciated.
thanx 🍺
normally your Dc-engine creates its own internal voltage inside the engine according to the Law of Lenz and this voltage tries to keep the current minimal.... we use the symbol E for this. We give the outside voltage what you connect to the engine the symbol U. The current depends on the difference in voltage U-E with U>E, therefore is
U - E
I = -----
R
Hello Everyone, Quick Question. Has anyone seen A1000 yaskawa VFD running a Brushless DC Motor? I'm assuming it is a parameter in the drive setup...
1,381
My job is to try to control brushless servo motor with frequency inverter. I just connected such motor to a frequency inverter and I tried running...
3,074
Hi everyone. I am planning to use PLC to control the speed of a brushless DC motor. The DC motor already came with a motor controller and the...
2,588
Hi, Everyone :site: I am a beginner to PLC. Recently, I am working on a project to build a door cycle tester utilizing Allen Bradley (1100) and a...
2,107
Hi guys, I have a problem with a brushless motor controlled by an axis controller. Sometimes the motor starts moving backward and I need...
2,952
