How to connect Allen Bradley 1100 to a Brushless DC Motor
chase_yq
Jun 2016
Fargo, ND
Hi, Everyone :site:
I am a beginner to PLC. Recently, I am working on a project to build a door cycle tester utilizing Allen Bradley (1100) and a Brushless DC34B/FV motor. My plan is to utilize the motor to drive a shaft-rail system which is connected to the door. As a result, the motor can open/close the door indirectly. The amount of cycles can be recorded and shown on LCD display of the PLC.
The user manual of the motor is:
http://www.bodine-electric.com/Asp/...15&Name=34B/FV Series INTEGRAmotor BLDC Motor
Based on my research, I need to use the PWM to control the motor.
Could any of you kindly offer me some suggestions on how to wire these two things?
If you have questions or feel unclear about my questions, please let me know.
Thank you all.
Hello, I'm not very experienced with plc's. Starting out. Is there a way to connect with Ethernet without using rs232. Unkown ip address. I can't...
1,601
Anyone here use the mb Connect with allen-bradley? I'm trying to connect the two but i cant seem to locate the TAP adapter V9 on RSWho. Any tip...
1,469
Hello Everyone I am trying to get online to a control logix plc. I get as far as seeing the ethernet hub in rs linx but , but rs linx doesnt see...
34
10,025
I have an Allen Bradley SLC 5/05 in my location and I want to connect it to my PC to configure a new CPU 1747 L552 in its rack. But, the serial...
21
9,269
Dear, I´m working now in my thesis of degree Electronic Engineering and I have the next problem I´m need connect the gateway wirelessHArt SWG70...
4,021
