connect labtop to allen bradley control logix plc through ethernet hub
There is no such thing as a 1769_c32
If you want help you need to post accurate information.
An Ethernet switch does not have an address and will NEVER show up in RSLinx.
What is the IP scrolling across the EN2T ?
Do you know what a Crossover Ethernet cable is? Do you have one?
Blanket statements are dangerous. Stratix switches do indeed show up when browsing in Linx.
Try pinging 192.168.1.10
"Start" -> "cmd" in Windows search box ->
"ping 192.168.1.10"
What version of Windows is on your laptop?
I conneated to a 5/05 with ethernet cable. When I do the saMe Rs linx Ab Ethip shows an active 1769_c32 ethernet port which is ethernet switch ,panel view but an x for control logix 1756_EN2T/A.
You might want to delete the Harmony Files prior to any other RSWho browse attempts.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/48241
Access Level : Everyone.
Upon completion, just grab any office pre-made patch cord, patch it in the switch and laptop, add another EtherNet/IP driver and browse with the newly added driver.
257
101
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
349
What has been your experience with year over year price increases on your Tech-connect service contracts? Is it up to the distributor? 30% seems...
288
