dc drive controller
Gemfree, how can you reasonably expect us to answer your question with so little information.
Please send us motor nameplate data, your AC supply voltage and the drive data.
Then we stand a chance of helping you. Not before.
Hi Guys
Can any one assist me in setting up a D.C drive coz I tried one and the armature current was very unstable
Here are some hints. Set current limit to nameplate rating. Check for proper field voltage. Check proper polarity for the series field winding. Adjust accel and/or decel. Adjust IR Comp to lowest setting, increase until unstable, then reduce setting slightly. Check brushes and commutator for excess wear. Check for mechanical drag in the load and the motor. Check bearings for wear in the motor and load. Many other things could be the problem, these are the first things to check.
Hello, I am running a AMCI SD4840 Stepper Motor drive system with Allen Bradley CompactLogix. Every now and then when a 480VAC motor kicks in on...
594
Hi, I need to connect with Pacdrive Controller & I want to take backup using "PacDrive Backup Tool". Can anyone help me in this regards. 1. Backup...
696
Has anyone tried to use a simple Ac Drive with an Advanced Motion Controller? To do a low cost angular synchronization on machines (Rewinders)...
2,409
I have an old GE S2K Drive / Controller that has been dropped into my lap to make changes on. The full part number is IC800SSI104S1A. I think I am...
2,666
What are the effects of the cycle time the PI control loop of the speedcontroller from a drive is executed? If I go to faster cycle times with the...
2,003
