DC to DC converter
Alan Case
Apr 2002
Wagga Wagga
1,268
Hi.
Has anyone heard of a 2 amp DC - DC converter that will take an input voltage range of 110V - approx 30V DC and output 24V DC.
So far all I can find from every manufacturer is an input range of 36 - 72 VDC. I am wondering if this is some sort of theoretical limit.
Regards Alan Case
Most DC-DC converters have a 2:1 input range, "wide range" is generally 4:1.
36-72 volts is from the telecoms industry (nominal 48V battery), not a theoretical limit. RS Components list some units with 72-144 V input, but I don't know of a 30-110.
Alan
Quantity of 100 units DC - DC 100 V to 24 VDC and with 2 amp output?
Is this in one room ie all within 200 feet or so?
Do you really have to have 100 separate units?
Can you do a single power supply?
Could you use a 24 volt battery ie forklift and forklift charger - should give you 200 amp for half hour without any problem and not charging. 4 good heavy 12VDC truck batteries would do the job easily. If just for a couple hour test take em out of trucks and use them charge them back up and put back in trucks.
Electric vehicles use DC DC converters but generally for 12 VDC and 30 to 50 amp and supplied from battery voltage as high as 325.
Dan Bentler
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
137
Problem: Our PLC can only output 4-20mA, but the actuators it needs to control, modulate based on a 0-135Ohm signal. Buying 4 or 8 individual...
277
I would like to install a non HART device in a system that uses HART, do you have a converter
104
Communication between devices will stop working for a certain period of time. I caught the error message using WireShark. I cannot identify the...
104
Hi all, I'm having a Red Lion DSPLE000 protocol converter on site to interface comms between an Allen Bradley L36ER CompactLogix, a S7-300 PLC...
521
