DCS signature Fanuc update
Amy_Fields
Aug 2013
Toronto
30
Could someone help me out and explain how to update a new DCS signature? For example if a Fanuc servo motor is replaced on the robot and remastered, how would I update the DCS signature in a Guardlogix 1756L7S processor that communicates through ethernet to the controller.
I'm assuming that your application matches what the Guardlogix is programmed to match what the Robot's DCS is reporting (or its in the h/w definition).
You can find the DCS signature of the Robot by using the pendant:
[menu][0:next][6:system][F1][8] key sequence will take you to the DCS directory.
use the arrow keys to move down to selection 16: Signature Number and press enter. You'll find the (4) DCS signatures listed there in decimal.
You'll need the Safety add-on or RSLogix/Studio 5000 Pro version to edit the safety routines or devices.
Hi everyone How i can configure a periodic report of the list of alarms? Thanks
102
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
290
Hi, I need to read three 4-20mA signals from a DCS(ABB) in a remote 6 channel analog input module with RS485 modbus port. When I connected...
492
I have a DCS instruction, that is set up for an E-STOP. I have the restart type and cold start type both set as automatic. I can test the e-stop...
397
Hello All, New to this forum. I'm reviewing two programs from two different integrators we have used. Both are using Guardlogix 5094-IB16S/A...
1,538
