DDE-Topic and Unsolicited message
mulderm
Jun 2003
Netherlands
298
Hello,
I have make a DDE-topic in RSLinx als Unsolicited message.
In RSLogix5 have I make a program with a MSG-instruction
and when it's enabled sending N7:0, N7:1 and N7:2 to RSLinx.
In Excel I have maked this hotlink, cel A1=N7:0, cel A2=N7:1
and cel A3=N7:2 in sheet "DDE".
This works perfect.
Now I have wrote some VBA-code:
In thisworkbook:
Private Sub Workbook_Open
Worksheets("DDE").Ondata = "Start"
End Sub
In Module1:
Sub Start
msgbox Range("A1").value
End Sub
Problem:
When I start the workbook the value in the cell is #N/B
and then the procedure is broken and get a message "error 13
mismatch".
When I have Reset this the value in the cells are 0.
When I enabled the MSG in RSLogix5 I see in my MSGBOX in
Excel "0" and the new value's are seeing in the cells.
Starting again the enabled of MSG I get the old value
seeing in my MSGBOX, but I will see the new Value.
Who can help me this problem?
NB I have use Unsolicited message to reduce traffic
mulderm
I have recently installed RSLinx Single-Node and I'm writing an Excel macro to read some recipe data from some PLCs. The macro is pretty straight...
2,287
Hi Guys, This is my first post so not sure what response I will get. I regularly use Excel to retrieve data from PLC's at work as it is quicker...
2,601
I have the following DDE Topic in Excel from a ControlLogix processor: =RSLINX|'SW123'!'CCip_Rcp[0].FiRns.Vol_Sp,L1,C1' It was created using a...
2,813
hi, Can you guys help me out in understanding the function of DDE/OPC , topic config in RSlinx software.
2,856
Hello guys, I have been trying since yesterday, I can't activate DDE TOPIC lists on RSLinx Classic Single Node. I've tried all configuration...
2,854
