RSLinx DDE Topic
toarts
Apr 2010
San Jose, Calif
30
Hello guys,
I have been trying since yesterday, I can't activate DDE TOPIC lists on RSLinx Classic Single Node. I've tried all configuration settings, that I can think off, change them around etc. I have succesfully load the activation license. I am trying to use DDE to get the data to Wonderware Intouch. Is ther anything that I am missing?
Thank you so much for any help.
Toarts
Hello guys,
Toarts
What Version of RSLinx are you using, what type of License?
What Operating System and Service Pack are you running it on?
What Version of Wonderware Intouch is installed?
What PLCs are you trying to Communicate with, exact Model and Versions?
What Communications type are you trying to use? i.e. DH+ etc.
What Driver in RSLinx are you using to Communicate with the PLC?
Are you In Support with AB, so we could point you to some Knowledgebase Articles?
Some Screen Shots might help too.
Stu.......
Thanks Stu...Please see below.
Version. 2.57.00 Full Blown Ver.
XP Pro SP3
Intouch 8.0
RXLogix 500 Ver. 8.30
AB_DF1-1 DH485
No
Thanks again for your help
XP Pro SP3
Intouch 8.0
AB_DF1-1 DH485
No
I am going to Infer from you answers you are trying to Communicate to SLC500 PLCs. Are these SLC5/03 PLCs? Are these direct Serial Connections?
Stu....
I have the following DDE Topic in Excel from a ControlLogix processor: =RSLINX|'SW123'!'CCip_Rcp[0].FiRns.Vol_Sp,L1,C1' It was created using a...
2,813
I've already setup DDE/OPC topic at RSLINX OEM version. I even copied the link to excel. Now I saved excel file into our company's network drive...
3,347
I have a spreadsheet thats populated via a DDE link which retrieves data from the PLC. This setup is working just fine but I want to add somemore...
12,730
I am trying to read some tags using Rslinx server thru DH+ in microsoft excel. For this I have configured a topic for that particular PLC(AB...
10,507
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
95
