DDE/OPC, topic config in rs linx
DDE = Dynamic Data Exchange is a Windows OS feature which enables interprocess communication.
A RSLinx OPC data server which contains established DDE Topics (communications links) will transfer data between the applications at "the ends" of the established DDE Link.(For example, an Excel document data could be written to a CPU data table or the live processor data table values could be retrived into a spreadsheet).
the difference between DDE & OPC servers are still not clear to me.I have come across these terms in rs view software as well.
By design, RSLinx is an OPC data server.(OPC = "OLE for Process Control (OPC), which stands for Object Linking and Embedding (OLE) for Process Control, is the original name for a standards specification developed in 1996 by an industrial automation industry task force. The standard specifies the communication of real-time plant data between control devices from different manufacturers"...Wikipedia)
DDE is just one of the means the OPC protocol could be implemented with.(Windows OS feature)
There are various OPC servers which do not use DDE. RSLinx uses it when configured to do so.
I've already setup DDE/OPC topic at RSLINX OEM version. I even copied the link to excel. Now I saved excel file into our company's network drive...
3,338
Hey Friends. I am currently trying to write approximately 700 tags from FtView13 to an Logix Emulate 5000. I am using rslinx DDE/OPC to create an...
398
Dear Friends; I copy the link of Tag value and paste it as a link in Excel but Cell shows #REF The images are attached where i am wrong...
772
Hi, I am gonna use Rslinx classic 3.9 to copy DDE/OPC tags' link from CompactLogix CPU to Excel through Ethernet/IP but It does not show any of...
35
12,096
HI, I created a RSLINX OPC/DDE topic and then copied the link in to excel and I'm getting a #REF Error in the cells rather than the data, anyone...
1,775
