Decoder for prosave
Nepiter
Apr 2010
At job
79
Hi!
Does anyone have anymore software for decoding prosave- file?
Google says that it is called DecoderProSave.exe, but all dl links are dead..
I do not have actual project file for op17, and I need to update panel (build it again.. o_O )
How can i get the decoder
Hello!!
I'm also searching for the decoder. I've been using several diferent search engines without luck. Do you know a working link?
Thank you,
Kelkoon
Hello does anyone give me a copy? Thanks in advance
I have it.. kind of.. o_O
I tried to upload it, but Windows does not allow me to do anything with the file, because there is troijan inside the file.
I guess some years ago, my virus software did not detect troijan.
Sorry.. :confused:
What does the decoder output ?
Just curious. I dare not actually run it.
Decoder push out .txt files.
All parameters and screens are in .txt format.
Some years ago I was able to get valuable info from old backup, with this decoder.
I'm not sure, if this trojan is really trojan, but virus scanner blocks file from using it.
I have it i will send a link in a PM
Can u send decoderprosave.exe link again? that is a big help, i have damaged op17 (but i have it backup .psr file), i need to reprogramme another HMI , but i couldn't to find it area pointer address, i hope ur help... thank u
Hi guys, I'm looking for a scetchy piece of software called DecoderProsave. I saw it being mentioned a couple of times on this and other forums...
38
16,884
Hi, I wondered if anyone has any experience using the Frontline net decoder software on DH+ with the U2DHP box? I'm running into a couple of...
1,406
Hi, We've been doing a lot of work to get our DH+ networks back as they should be, following years of poorly executed modifications. We've...
1,556
This app has multiple modes which control different combinations of pumps, valves, instruments, etc. I'd like to do this using bit control...
2,733
I am comparing and contrasting the differences between an encoder and decoder and am slightly confused. I understand the general purpose for an...
4,285
