Delta DVP-14SS2
Oct 2014
Surat
I am new use of plc .
I am using delta dvp-14ss2 model plc so can please tell me which communication cable i use for my laptop to delta plc
laptop model-aspire E1 Series ,Z5WE1 ,acer
reply soon please
regards
Pankaj
delta dvp plc cable
Dear danatomega,
Thanks for reply
But my quiry is usb cable is ok or not ok for plc programing
2nd think
In my laptop 15pin rs 232 female port so which one i use .
It would be a rare item indeed - 15 pin serial. More likely it's a 15 pin VGA video connector. 9 or 25 pin serial is all I have ever seen.
So, to answer your question, the link I sent you is titled "Communication interface PC to DVP (Delta PLC)" and includes a USB to serial connection section. They sell a USB to RS-485 converter that you may want to check out.
They also have section on wiring RS-232 to PLC RS-232 port cable.
Hello, someone know how to configure this PLC (DELTA DVP-14SS2) In the COM2 modbus RTU 485 baud rate 9600 8E1 slave mode (Not the plc Link)...
1,482
Does anybody know how to perform a factory reset on a Delta DVP-14SS2? The device suddenly stopped responding to WPLSoft and I would like to try...
7,827
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
64
Hey guys, I've a requirement that a two different PLC program should work in same system depending upon user input. Consider Program A is used...
1,932
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,355
