Delta PLC Communication issue
ajit.nayak87
Feb 2012
bangalore
Dear all
I have DVP14SS211R series Delta PLC Which is having 24V DC supply voltage. I am using PLC as master and My end device as slave. My slave device set device_iD=1
I am using Modbus RTU protocol for Function code1
baud rate =9600
parity =none
Stop bit=1
data length=8
I would like to know how to send request with Function code 1(Read coil Register). i have attached code reference. Communication block it wont give error it shows 0 .means No error
I would like to know What is the Address to be set for MODRD/MODWR/MODRW function. If my salve id set is 1 FC1 start address 1 length is 32.
I have checked i made it correct . But i wanted to what should be register to get value.
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
117
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
283
Hello, I'm facing a problem in communication between my delta TP70P-32TP1R HMI and DVP20EX2 PLC. I tried multiple ways in order to set the...
1,339
Hi PLCTalk Family, I am currently using S71200 for UDP communication in one of our projects. Recently due to the chip shortage looking out to...
1,290
Hi, I want to communicate slc5/03 cpu with Delta tp04 hmi through rs232 port. I tried through 1747cp3 cable directly but can not communicate...
934
