Delta PLC real time monitoring and recording
Oct 2017
Thailand
Dear all I need help for delta plc programming .
I can use DVP-12SE PLC and HMI DOP-B10E615 as they both support ethernet.
I am planning to make ladder logic in which whenever a register (M0) become active , the plc program should start recording the time interval .. and when M0 disable the timer should stop.
Let's say:
M0 become active at 09:30am and stops at 10:30am on 18 July 2020 ,so the total time M0 is active is 60 minutes ..
Now, let's say M0 again become active at 13:00 and stops at 15:00 on 19 July 2020 , so the total time M0 is active is 120 minutes.
Now, my problem is this that I want to make a ladder program and HMI recipe so that I can see these active times whenever I want.
let's say all this data is somehow recorded in HMI (I don't know how) and someday I want to see on what day for how much time M0 was active , and I can export those data into excel file.
Can anyone help me . In simple language I want to keep the records of error of machine, when and for much time the error(alarm) was active.
Hi all, I'm planning to set a timer that everyday each 1 hour to on pump. And If the power trip and then to on back the PLC, the plc still...
4,742
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
48
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
119
I have downloaded COMMGR 1.15 software on my laptop. After downloading it works. When I stop and start the program again it doesn't work. It is...
154
How i Can connect Delta plc, with Beckoff remote IO cards?
180
