Delta V analog output isolator
Jason P
Jan 2006
Burlington
22
Hello,
I have a Delta V system that has an active analog ouput card that would supply the power and signal to the device but I want to put an isolator in between but cannot find a unit that will have an active output to power device and loop powered on the Input to power isolator?
Am I missing something?
Phoenix contact makes a loop powered (passive) isolator
MCR-1CLP-I/I-00, p/n 2814016
description from manual:
"MCR-1,2,4CLP-I/I-00 passive isolators are used for
the electrical isolation and processing of analog
0(4)… 20 mA standard current signals. The blocks
provide electrical isolation between the control
electronics and process I/O. In addition, interference
signals above 75 Hz are effectively suppressed.
Input and output circuit do not require separate
auxiliary power. The modules obtain this power from
the input signal."
datasheet:
http://rd.phoenixcon.com/products/interface/db/datasheets/2814016.pdf
manual:
http://rd.phoenixcon.com/products/interface/db/datasheets/MCR-124_CLP.pdf
Dan
im trying to configure hand indication control (HIC) i doing the following: 1- configure AI,MANUAL LOADER,AO in control studio named as...
1,193
1,909
Hi, I am working on a project with Delta PLC for the first time. I want to connect a Sinking analog sensor (4-20 mA) to a Delta analog module...
1,663
Hello guys, I have a pressure sensor with 0-10 control and 0-600 bar range. how can i read from it the signal and transfer it to bar and stored...
20
7,719
Dear all I am using delta AH530 RS- 2 cpu with devicenet communication and now I am getting problem while configuration of AH6xa-05 which is...
1,041
