Delta WPLSoft Offline Programs Compare
mjoubert
Jun 2007
Pietermaritzburg, South Africa
192
Can anyone tell me how to compare 2 offline programs so that I can see what differences there are between the 2 programs. This is quite easy for Omron, Mitsubishi, Lenze PLC Designer etc. but for some reason this function seems to have been omitted in the Delta software.
I use Beyond Compare from Scooter Software to compare files. Depending on the file type though, the results can be interesting. Compiled files can be crazy looking, but text based files are easily compared (xml, .txt, .bat, etc). You can even equalize differences in the files. Also, its free.
Its a file compare. Depending on the type of file you compare it will look straightforward, or look like a mess. It shows the differences in the contents of two different files. If you right click on the file you want to compare and try to open it with a text editor like notepad or notepad ++ and it looks "normal", Beyond Compare will work great. If you open the file in a text editor and it looks crazy, it won't work for you. Its free though so its worth a shot, and if it doesn't work for this application its still a handy tool to have.
Hello , I'm using DVP12SE11R Delta PLC . I would like to read data from an external device using RS485 communication. In the WPLSOFT i have...
1,817
i don't have delta plc but i have its programming software wpl soft i make programes on that software but when i turns on simulator and debug it...
5,916
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
48
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
120
I have downloaded COMMGR 1.15 software on my laptop. After downloading it works. When I stop and start the program again it doesn't work. It is...
154
