Hani Abdullah
OP
I have done that All relays in parallel (with different switching levels) and heaters in series with each relay. Is that correct?You need to show us your work. What have you done?
I cant understand what you people are saying
No, you are far from the correct relay-logic schematic diagram. The relays should not be in parallel unless you need two to provide more poles than you can get on one relay. The heaters should NOT be in series with each relay.I have done that. All relays in parallel (with different switching levels) and heaters in series with each relay. Is that correct?
The heaters should be shown on a separate power wiring diagram, not on the control diagram. You were not required to draw the power wiring, only the heater controls.Design the relay ladder logic for this Control.
