Detect Panelview Screen Saver Activation
Steve Cav
Aug 2006
Clitheroe
71
I have a Panelview Plus 1000 and have the screen saver set at 15 minutes. However, it has been requested that on screen saver activation the Panelview screen changes to the 'Main Menu'.
Reading through the manual etc there does not seem to be a way to determine screen saver activation.
I could monitor the screen number and whether any buttons etc have been used for 15 minutes etc but is there a neater way to achieve this?
Steve
I just set one of these up yesterday. On the menu that has the screensaver or "timeout" setting checkbox, there should be a selection for screen to be displayed upon "wake up". This may depend of the version of software (ME) that you are using. I'm on ver6.0
BD
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
391
Hi all, I am trying to find a way of detecting a motor is not isolated before attempting to run an inverter. We would normally use a 4 pole...
19
3,084
Hello everybody, I have a vendor system that has some remote monitoring (read only) and remote control (read/write) data that is available via...
2,876
1,221
Hello.We are using S7-300 Cpu.Sometimes give an error.OB86 and OB122 blocks called.OB86 Block ; L #OB86_FLT_ID T...
1,932
