CapinWinky
I have a 1756-DNB on my main rack that is supposed to communicate with a 1769-ADN with some IO attached in a different cabinet. I can see both modules with RSLinx and they are both in an RSNetworx project.
The issue I'm running into is I cannot download/upload any configuration data to the 1769-ADN module. Each time I do, I get this error entry in the log:
CHAS:5005 Address 01:[Slot 01] Communication Error(0xC) 'Error response received: [0x0416, 0x0000]. Object does not exist.',SCIA(0x19,0x2403,0x0,0x1A).
That is followed by:
CHAS:5008 Address 01:[Slot 01] 'ProxyAssem4' was skipped.
I have a new install of all the AB software and I'm commissioning my first AB machine, so I've run into tons of problems that were resolved by installing a seemingly endless stream of AOP, FW, and EDS files. However, the FW installer for the 1769-ADN is not compatible with Windows 7 (I was able to install the EDS file though). Researching this error, I've seen a lot about EDS files needing to match the firmware version because they are constantly adding and removing parameter entries. I have a module with v2.005 and an EDS file named 0001000C00450200.eds (eds last updated November 2005).
This is a repeat machine, so I have a known working .dnt file and a new .dnt file I tried creating step by step from scratch. Neither is able to transfer configuration to the 1769-ADN module.
