Device Net with AB 50/4 and ABB Drive
Thanks Alan.....I talked with ABB, and as others have stated, the support was not good....Thanks, I'll be in touch with you if I have any issues, as well as posting detailed results when I'm done. I am fortunate in that I have plenty of time to get this done, it's not a time critical project.
Greg
CJ1W-DRM21 OMron master used with RDNA-01
Has anyone tried this combination? I can get the limited eds file to work, but as soon as I use the full version eds, for some reason I can't access all the parameters. In my Configurator it says "Attribute not supported" when I try and upload parameters from the RDNA-01. Does anyone have a CLUE? I have been trying everything. Could it be that there is so many parameters that my master just won't take it all? May be a stupid question, but I am totally up to any suggestions????
Or if anyone has used this RDNA-01 with any other vendors Devicenet master....in order to get all the other parameters out of this device....did you have to use Explicit messaging????
What is RDNA-01? I have used the CJ1W-DRM21 with a variety of devices and brands without any trouble. For example, the AB Powermonitor 3000 has an enormous amount of information to extract and it is definately by explicit messaging.
RDNA-01 does not bring up any matches in the search engine at the AB website.
I ended up using SSD (Eurotherm) drives in the end with devicenet and it was a breeze. Been busy but will post some panel pictures soon and an update on the 5/04 through dnet to a 590+ and 690+ with files for anyone thats interested.
Hi All we are looking for a expertice people for develope new secuence in a robot ABB controlled and some I/O points configuration computer...
5,355
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
147
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
349
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
349
130
