Device Net with AB 50/4 and SSD (Formerly Eurotherm) Drives 590+ & 690
504bloke
Jan 2005
Down South
2,721
I have just finished testing some panels and have attached the devicenet and logix files
Apart from rung comments etc is there anything i am missing here ?
I wired and tested the units and all seems to work fine
Never having used devicenet before i thought id ask before i wire up on site and have any problems with the software
i have just included in the logix software the devicenet stuff only for clarity!
The Scanner is on Rack 1 Slot 11 and is talking top a 590+ DC Drive and two 690 AC Drives
I have configured the SSD drives with configedlite and they seem all ok, ill attach the drives config files tomorrow as i have left these at work!
I am new to this site and am amazed about how much information is here. I just finished a project using Control Logix and DeviceNet at a Steel Mill in Georgia and will take a look at your project files. It is always interesting to look at how others write their logic. I learn something every time. If I see any problems from my limited experience I will let you know.
Dale
Dale
Thanks, all comments welcome
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
We have some very old technology in my plant that needs adjusted but I don’t have the equipment. Can anyone tell me what I need to program this IO...
355
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
351
132
We are trying to set up a newer generation Omron PLC (NX/NS Series) with Citect / Aveva Plant SCADA using the Ethernet/IP CIP Protocol to read...
371
