plcduck Member P Join Date Nov 2011 Location norfolk Posts 12 Feb 13, 2012 #1 how do i decide/determine which stores are being brought back to the PLC....when using a power flex drive with a 20-comm-d module
beethoven_ii Lifetime Supporting Member B Join Date Nov 2006 Location Central England Posts 409 Feb 13, 2012 #2 What do you mean by stores? If you're referring to parameters then you have to use explicit messaging and specify which parameter you wish to read from or write to.
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,794 Feb 13, 2012 #3 It also depends on how you configure the scanner, the drive and the 20-COMM-D module using RSNetworx for Devicenet. For good info, you need to tell us which PLC and Powerflex drive you are using and whether it is standard or enhanced control.
plcduck Member OP P Join Date Nov 2011 Location norfolk Posts 12 Feb 14, 2012 #4 its 1769-l32e 1769-SDN EDS file name for my power flex is - SMC Flex std (5-35)
widelto Member Join Date Jul 2005 Location Barranquilla, Colombia Posts 3,392 Feb 14, 2012 #5 PLCDuck: If not used already, use devicenet tag generator, it will save you a lot of work. For parameters saving or writing use messages.
