Devicenet Configuration - Backup Issue
karimhalawa
Jun 2017
6th Of October City
I have DeviceNet network connected with controllogix PLC by Scanner 1769-SDN .
I Have backup for all drives and flex I/O connected over this network .
My scanner is faulty now and i have to replace it by new one ,
when i opened my back-up configuration and try to downloaded it to the scanner , i have found two scanner .
the first one is the original one with node address 0 and the new one with node address 63 .
Just i want to know how can i download all configuration ( backed-up ) to the new scanner without this conflict .
The backup has two Scanners because the second one was connected to the DeviceNet network prior to the backup to be performed...Any device connected to a live DNet will be 'assigned' Node Address 63 by the 'functional' Scanner...
The 'functional' Scanner is the one containing the Scanlist.
Just delete the second (Node 63) 1769-SDN from the RSNetworx for DeviceNet file; verify the Scanlist and I/O mapping; verify the devices' configurations; Save the file and download it to the replacement Scanner.
hi there if i have a slc 5/05 set up with 3 devicenet scanners and want to upload a backup file of the networks in rsnetwork. can you browse so...
2,048
We refurbish tube end formers and benders. I'm currently working on an Addison TEF. It has a 1769-L32E with a 1769-SDN DeviceNet scanner (see...
1,647
Hello, As some of you may have seen in another thread I have a deviceNet network of valves and realised that no one saved the network...
2,195
One of our PLC control systems lost its Device Net configuration parameters when we performed a scheduled plant electrical shutdown. We had to...
2,209
Hi all, I have multiple Allen Bradley SLC5 PLCs on my site, with most of them having a DeviceNet card installed. Each PLC also has an Ethernet...
2,370
