DeviceNet Vs. Ethernet
iahiii_2005
Jun 2008
Oslo
Hi All,
I am having some difficulty understanding a customers's network architecture.
They have a PLC1 that communicates via Devicenet to MCC(Motor Control Center,they pick up pump status for etc) and then the PLC1 communicates via Ethernet to PLC2 and PLC3.(PLC2 and PLC3 need the MCC pump info to operate)
Why would that be,why can't it be devicenet from PLC1 to PLC2 and PLC3,or why can't it be Ethernet all the way round meaning PLC1 Communicates Ethernet to MCC and then communicates Ethernet to PLC1 and PLC2.
It would be of great help if someone could give a link or reference to Devicenet Basics and Ethernet Basics.
iahiii_2005 said:
Hi All,
Well, I'm thinking that a Devicenet scanner for the two other PLCs would be more expensive than an ethernet scanner.
Also, Devicenet, as its name imply, is really focused around devices, and the MCC is filled with devices (COntactors, drives etc.). If the other 2 PLCs only need status information and are not really controlling the MCC, then going Devicenet would be expensive.
As to why not go ethernet all the way, I can guess that they want to keep the diagnostic info available in Devicenet between the MCC and PLC1.
Just guesses :)
Hello, This will be my first time converting powerflex 40's and 400's from devicenet to ethernet. I did some research, and it seems I will need...
780
A customer has a stamping press that has 2 DeviceNet nodes going to a DeviceNet control card in a ControlLogix rack. Older ControlLogix, L55...
41
15,155
Hello Team, Is there a way to explore DH+ Networks like there is for EIP and Dnet? Thanks! -PreLC
1,727
So I have a system that is running on DeviceNet. We have been having nothing but problems with it for the last 3 years. I am trying to switch...
1,287
Hello Experts, I would like to post a question about migrating DeviceNet to Ethernet. No change in PLC and number of IOs. Just network migration...
2,740
