DH 485 link coupler
urlauber1
Mar 2006
south boston va
Hello all,
I have an Allen Bradley dh485 link coupler that I don't know how to test. I have a 1747 pic device but the driver is not supported using windows 2000 or higher. We are using a cuttler hammer 1570 pm panelmate connected to the dh485 link coupler. Then another link coupler to the dh485 connector on a slc 5/03.
The error message on the panelmate reads "LOC: 2200 on ?? via port 1 proc. data from 2 "
The original panel mate smoked and we installed a replacement that was pre programmed from the oem. Any thoughts on this appreciated
I am new to this site...hope this is the correct way to ask for help.
dean
I know the pic driver works in 2000 and xp only if the machine has a rs232 port.
How do you get on-line with the 5/03?
Assuming a laptop with a pcmk card .
You can use this to plug into the link coupler and maybe the panelmate should show up ?
Drewcrew6
My knowledge goes back a ways but it used to be that for DH-485 communications to a PM 1500 you have to install a license file which comes on a one time use diskette. If the OEM didn't follow this step when they programmed the unit then it cannot communicate of DH-485.
I believe during boot up the screen should mention if this option is installed or not.
For connecting to a Micrologix through a 1761-NET-AIC, the manual specifies that you should use "RS 232 Communication Cables Cable, Cat. No...
1,368
Hello forum, Simple question from a newbie. We have a PV600 showing all nodes in error. The Link coupler power LED is not illuminated and a...
2,017
I replaced a PanelView 600 with a PanelView Plus 1000, graphics was successfully transferred over. When connecting the D-485 Link Coupler via the...
3,608
Hey everyone, I'm just looking for some input on the the network architecture when dealing with DH485 through the 1747-AIC Link Couplers. First...
4,696
Hi Im after some help again. Ive just been diagnosing a communication problem. The system comprises Windows 98 PC running OEM Software. Linked to...
4,146
