dh+ opc server
Amr Hassan
May 2005
340
i need to connect 2 wincc flexible workstation to AB plc on a DH+ network .i am intending to use an opc server on each workstation
my questions are :
what ab hardware , additional components is needed.
is it possible to use 2 opc servers on the same bus.
please recommend an opc server and give me an estimation on the price
\thanks
You need to purchase a 1784-PKTX card and RSLinx OEM (dont know the current type number). Be sure that a full-height (but half-length) PCI card can fit in the PC.
There is no problem with using 2 PCs with OPC servers on the same DH+ network. But keep in mind not to overburden the network. DH+ may start to be at the limit from 7 stations on the net, depending on the amount of traffic per station.
hi Jesper , you are "weclome" lol.
This is something like simatic net i guess ?
The opc server provider asked if PLC’s are connected via Ethernet, Serial or PKTX , frankly i do not know , all i know it is DH+ and i am using the 1785-bcm modules. could u tell how could i know that?
Yes you will need a 1784-PKTX card, and RSLinx OEM.
RSLinx is indeed like Simatic Net. Only it is a bit easier to navigate. :)
1785-BCM , backup communications module.
As far as I know (very little) it is used to provide redundancy for RIO and DH+ with 2 PLC processors.
I think that it works completely transparantly to the outside world, switching between the 2 PLCs on the fly. And that I think means that for you (and the PC with the PKTX card and RSLinx) it looks like 1 PLC. Better verify with someone who knows more than me.
Cheers, and gdoo lcuk.
dear Jesper
What u have mentioned about the bcm module is exactly what i know about it . but how do u know it is pktx?
1784-PKTX is a PCI card (notice, the old PCI standard, not PCI extended !), and it supports both RIO and DH+ (and even DH485 but that is irreevant to you).
I am 99% sure that you need a DH+ connection to the PLC(s).
edit: To keep the comparison with Siemens products, then an AB PKTX card is similar to a Siemens CP5611 card.
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
273
If anyone has a crack for IBH OPC Server, please send it to: [email protected] Urgently. Thanks in advance!
139
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
195
Hello everyone, I wanted to share my findings with getting the new OPC UA server working (I think you might be interested in this JeremyM :lolis:)...
2,155
I have a Win10 64 bit host for my OPC DA server, which is Indusoft (Studio,Scada.OPC.3). Locally OPC works, Matrikon OPC Explorer. On my Win7...
1,196
