DH+ resistor temperature
andy_1983
Mar 2018
uk
76
I’ve been doing some tests with a new PC based oscilloscope on DH+, just getting my settings right etc. To facilitate this I strung 1mtr of blue hose cable between 2 racks running on my table. Set my scope up ok, but i then noticed the termination resistors were really hot.
I’d used a 150ohm 1/2W resistor at each end.
Tried measuring the temperature On my fluke, and it got up to 70deg C.
Is this normal? I’m not one for going round feeling resistors - but I thought these were a bit hot....
Andy
Thanks for the help. I’ve done some more testing.
The resistors that we’re running at 70degC we’re blue bodied ones.
I’ve done the same test again, but I’ve dug out some old resistors that were on some salvaged PLCs. One has a dark brown body, the other beige. Both are 150 ohm.
The brown resistor runs at 43 degC
The beige resistor runs at 45 degC
Looking at this it seems the brown resistors are a better option. Unless the blue ones I’ve got are not good quality.
Andy
Let's say I have an inverter fed three phase induction motor drive where in the braking phase (when the motor operates in a generator mode) the...
145
Hi all, We are installing a number of Profibus actuated valves (Auma AC 01.2). They have a terminating resistor on the PCB but the system...
921
I have a vector drive faulting out. Manual says inspect and test the Braking Resistor. I have never done this procedure before. === From...
2,719
Hey all. I dont know if this belongs here but I have a High Resistance Ground unit that is displaying a resistor fault. Anyone have knowledge on...
2,846
Is it possible for multiple PF 755 drives configured for dynamic braking to share a single braking resistor?
3,525
