DH485 with Rs232 problem
themodyman
Dec 2010
Qizza
i have a communication problem with four SLC 5/3 connected to each other by DH485 and with PC through converter by RS232
but i want to get the data from the four PLCs without changing the SCADA[INTouch]-which is a local one- over the internet to a remote location so i can setup new SCADA[ClearScada] for monitoring only without control
what can i do?
Get another DH485 to RS232 converter for, or put a DH485 compatible RS-485 port in the new SCADA PC and hang it on the DH485 network.
Or bridge through the existing SCADA (if possible). If the existing SCADA is using RSLinx Gateway for communication to the DH485 network, then you should be able to connect the two SCADA machines and share that driver using the RSLinx driver called "Remote Devices via Linx Gateway"
I agree that the simplest thing would be to upgrade the existing PC license to RSLinx Classic Gateway and connect it using a VPN across the Internet.
This might not be practical due to nontechnical reasons of security or responsibility.
My recommendation is to use the 1747-UIC USB to DH485 converter on the second PC, along with RSLinx Classic Gateway.
I do not recommend a 1761-NET-AIC or 1747-PIC device because of the stability and setup problems with the old "1747-PIC/AIC+" driver in Windows NT/2000/XP/Vista/Seven.
need to set up to load applications to the PV1000 RS232/DH485 thru a SLC 5/04. Laptop is usin a PCMK to the DH+ on the SLC and the SLC is...
1,779
Hello Everyone. I have converter USB to DH485 (1747-UIC). I have problem with RS485(DH485) - RJ45 port. (manual switch is ON to RS485/DH485) i...
3,152
I have an SLC 500 and was wondering if I installed a 1747-KE modual and then ran the RS232 Port to my comunication server am I heading in the...
1,801
Dear Folks, I have to trouble shoot a panel which have one SLC 5/03 PLC and one PV550. I can communicate with SLC 5/03 using USB to RS-232. But...
4,714
Hello, I have a Panelview 550 Model #2711-B5A5. It is set up with a RS232(DH485) port. I Cannot get online with it. I am using a 2711-NC13...
3,324
