RS232/dh485 cable to RJ45/Dh485
Oliver Micka
Oct 2015
Hlohovec
65
Hello Everyone.
I have converter USB to DH485 (1747-UIC).
I have problem with RS485(DH485) - RJ45 port. (manual switch is ON to RS485/DH485) i cannot communicate to any PLC via this port..
I was try second converter ( same 1747-UIC but borrowed ) - after I set the same communication via RSlinx all function was normaly and i saw any DH485 stations..
I want try used a DH485/RS232 port but i want create cable from RS232(DH485) to RJ45.
Dh485/Sub-D9 female ------> Rj45/DH485.
I cannot found pinnout the same cable which I need. Please can we help me?
Many thanks..
but i would like to create cable between Rs232 port ( DH485 ) to RJ45 (DH485)...
Original this convertor have RJ45(DH485) but this port NOT function..
I would try RS232 port ( which use protocol DH485) but I must create cable between Rs232 and Rj45.. I cannot find pinnout for exactly cable which I need..
I dont think it will do what you are looking for... sounds like someone has used the wrong cable and burned up the DH485 port
What port on the PLC and what PLC are you trying to connect to?
need to set up to load applications to the PV1000 RS232/DH485 thru a SLC 5/04. Laptop is usin a PCMK to the DH+ on the SLC and the SLC is...
1,778
I have an SLC 500 and was wondering if I installed a 1747-KE modual and then ran the RS232 Port to my comunication server am I heading in the...
1,801
i have a communication problem with four SLC 5/3 connected to each other by DH485 and with PC through converter by RS232 but i want to get the...
2,160
Dear Folks, I have to trouble shoot a panel which have one SLC 5/03 PLC and one PV550. I can communicate with SLC 5/03 using USB to RS-232. But...
4,713
Hello, I have a Panelview 550 Model #2711-B5A5. It is set up with a RS232(DH485) port. I Cannot get online with it. I am using a 2711-NC13...
3,324
