DIAX04 Rexroth Indramat drive
mumix
Sep 2023
koln
Hello, what program is it used to connect with laptop a rexroth indradrive HDS02.2-W040N-H(verry old model), i'm guessing because its old so on a xp laptop would be need ?
You may need to create a virtual machine with an early version of windows to run this software. Send me a PM with your email. I believe I have an older version of the software.
Hi Mumix
You need DriveTop for this drive controller, see attached.
I am using DriveTop 16V14.
EDIT: It has both drive controllers you mentioned, however it does not support the older firmware.
You may need to up flash the firmware with DOLFI, or use an older version.
Versions 4V05 and 11V01 do not allow you to find or configure a drive of this type. I think it must be 16V14.
Apparently there are a lot of these systems still running the field today so I thought perhaps this information might be helpful to someone in...
91
Has anyone put together a combination of the Beijer iX Developer software and a Rexroth L54 controller over ethernet? Can't seem to get the...
552
Hi All! I have a project where communication needed between an Allen Bradley CLX and a Rexroth CML25. Do anybody have experience with it? We...
788
hi everyone! we need to update the program in the servo, a Rexroth Indramat PPC-R02.2N-L. The thing is we need the software for it, WinPCL...
771
I'm having quite a time figuring out specifically what software is required to view/modify the program for a PPC-R22.1. I believe it to be...
932
