Difference between a plc and microcontroller
sskki
Jun 2003
What is the difference b/w a plc and a microcontoller since a plc contains a microprocessor, memory, interface ports like a microcontroller. and working of plc is similar to that of microcontroller
A PLC will not fit in your wallet, a microcontroler will.
A PLC has nice LED on its cover, a microcontroler has no cover.
A PLC can sometime be snap unto a DIN rail, a microcontroler cannot.
A PLC has inbeded smoke which can be released with various technique, a microcontroler will just change from glossy black to black.
A PLC is a 3 letter word, a microcontroler has more.
A PLC can make a nice traffic light system on its own, a microcontroler need other parts connected to it.
A PLC cannot be welded to a circuit board, a microcontroler can.
A PLC can communicate to the rest of the world, a microcontroler cannot.
An old PLC can old my office door open, a microcontroler cannot
Want more?
If you really want to know, a microcontroller is just a limited microprocessor chip usually programmed in assembly language. It requires hardware be connected to it before it can do anything useful. Even though more advance now, older PLC's required a form of a microcontroller in it to run.
PLCs have in built watchdog timers that are monitored by the firmware and they check the programme from one scan to another. If the programmes do not match, or the watchdog timer times out they shut down.
:confused:
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,834
Hi All, I am starting a project that contains RTU from SCADAPack 474. However, I have no experience with this equipment, I am familiar with...
3,213
Hello, Do you know what is the difference between the PID controllers PIDFF, PID1 and PIDP1 in a Schneider PLC? I have to modify a PLC program...
1,740
HI all, I have exported csv files from one of the application which was build in factory talk view. I'm seeing 1600 tags almost and doesn't...
2,331
I was just wondering why a setup would be referred to as a DCS rather than just a standard PLC system? I was on a site the other day and it was...
2,077
