Different types of Relay
UKB
Aug 2014
UK
56
I'm struggling to find any descriptions of the different functions provided by these various relays in the mitsubishi documentation (surprise surprise)
Can anyone offer me some definitions, are these typically the same across the PLC board?
Where might I use a step relay instead of an annunciator relay etc..
Are there such things as annunciators and step relays in AB, Siemens, GE,
etc..?
Whats a link register when compared to a data register? or even link special?
Kind Regards,
UKB.
etc..?
Step relays are special-purpose relays that are designed for dividing a program into incremental steps, so that each set of rungs or networks is only active when the step relay assigned to that step is active or energized. Annunciator relays are used to send alarm or other or messages to the operator or HMI panel.
The following PLC devices (really instructions being run by the Central Processing Unit in the PLC) function more or less the same from PLC brand to brand, with minor variations (such as different symbols and addresses):
Output Relay
Internal Relay
Latch Relay
Edge Relay
Step Relay
Timer
Retentive Timer
Counter
Data Register
The other items on your list may be missing completely, or implemented very differently in different brands and models.
thanks guys,
I'm interested in the step relay as I have constructed most of my ladder as a sequencer, which sounds very similar to the step function.
I will make a more detailed post when I'm at home later,
this is a scrn dump of the manual, a nicely constructed list unfortunately for greenhorns (me) there doesn't appear to be any further explanation as to the nature of the devices :(
Mitsubishi used to have a manual with descriptions and examples of each command. I suggest you contact your vendor for assistance.
(And most bales nowadays are round, Ronnie!)
Active Homing When the axis Homing Mode is configured as Active, the physical axis is first activated for servo operation. As part of this...
1,849
Hi guys! 1 week until examination and i was woundering if someone here could give me an explanation on what the difference between Rated range...
1,511
Dear Experts I have a new CPU 6ES7 313-6CF03-0AB0 . my program is built on CPU 6ES7 313 6CE00- 0AB0 . when I try to down load to the new CPU I...
1,265
I want to compare an actual speed value (PIQ "Real" data type) from an analogue input, to the setpoint (0 - 100%)that is input on the HMI to the...
3,649
i am trying to learn plcs ( going to school at night ) and working for an automation contractor by day doing small pieces of large projects . i...
8,543
