What is the different between Allen Bradley Homing Types
amiraizat124
Jul 2018
penang
Active Homing
When the axis Homing Mode is configured as Active, the physical axis is first activated for servo operation. As part of this process, all other motion in process is canceled and appropriate status bits are cleared. The axis is then homed using the configured Home Sequence, which may be Immediate, Switch, Marker, or Switch-Marker. The latter three Home Sequences result in the axis being jogged in the configured Home Direction and then, after the position is re-defined based on detection of the home event, the axis is automatically moved to the configured Home Position
What is the different between Immediate, Switch, Marker, or Switch-Marker?
Immediate - the axis' current location is immediately set as the home position;
Switch - the axis is moved until the home switch input is triggered;
Marker - the axis is moved until marker pulse (Z pulse of encoder) is detected;
Switch-Marker - the axis is moved until the home switch input is triggered. Then the axis is moved until marker pulse is detected.
124
Hi, If we have PLCs on different subnets is it possible to do TCP comms data transfer between them? I'm assuming if we use a routing switch and...
823
Is there any issue introducing wires from a different power supply to my enclosure? Currently, I have an HMI that will be powered by one...
1,727
Hey! In my previous queries on how to handle an OPC server like RSLinx in the ArchestrA IDE galaxy, I have succeeded and the answer was to just...
1,823
Hi, Does anybody have experience with Ethernet/IP-CIP Safety comms between 2 different brands of PLC's I have a project with 1 Safety Allen...
3,580
