Differential Eddy Current Probe
GaryP
Nov 2005
Perth
Does anyone know of a source in Australia for a differential eddy current sliding probe with a holdoff of around 1mm that I can use for surface crack detection on bar stock moving at 1.5 meters / second? I want to bring the information into Labview. I know this is not really a PLC question but hopefully someone will know the answer. And no I cannot use a optical system or ultrasonics.
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
153
Can the built-in high speed counter on an AB Micro850 only use single ended encoder inputs, not differential? I'm trying to get a differential...
304
Hello, friends my 1756-if16 differential connection, has been used again (almost 10 years), the measurement value of each channel of the entire...
976
I am updating controls on a leak tester, from a SLC 5/02 to Compact Logix. The SLC used a DDV instruction to help scale a differential pressure...
17
4,447
Any recommendations for a DIY home automation suppler that has a inexpensive WiFi device that I can use to monitor my HVAC filter. Thanks, Bob O.
3,336
