Differential line driver encoder / Duty Cycle ?
milmat1
Aug 2005
North Carolina
209
I have a Differential line driver encoder (Dynapar HS20....)running at 12VDC ...
Am I correct to assume as frequency of the encoder output (say CH. A)varies with the RPM of the driven shaft, the measured duty cycle should always be 50% as measured on my Fluke 87 DMM ? (not counting imperfections in the encoder disk etc.)which would vary the reading by some small percentage...
I'm pretty sure that it will remain at 50% since that's how the lines are set up in the encoder.
I'm so sure that I would say that 100% of the time it will be a 50% duty cycle. But, then, I could be wrong ...
Changes in speed will generate momentary variances from 50%, else how would the frequency change? At least one of the half cycles must be a different length than its predecessor to arrive at a new frequency.
Bernie, True that would happen during the change in frequency, but at a stable speed the output from the encoder channel is going to be on 50% of the time right ?
I need to immediately build a circuit, to use an Omron Open collector single-ended encoder to Trio differential line driver input. The encoder...
3,445
I am converting a SLC 500 to a Compact Logix. I plan on using a Compact Logix 5380 with conversion Kit. The problem is that the analog input cards...
152
Can the built-in high speed counter on an AB Micro850 only use single ended encoder inputs, not differential? I'm trying to get a differential...
304
Hello, friends my 1756-if16 differential connection, has been used again (almost 10 years), the measurement value of each channel of the entire...
976
I am updating controls on a leak tester, from a SLC 5/02 to Compact Logix. The SLC used a DDV instruction to help scale a differential pressure...
17
4,441
