Difficulties locating a DP pointer
emmaus
Aug 2014
Finland
Hello All,
I am beginner at Siemens S7 and I've met a problem. I need to find a location where a DB pointer is written but it seems like an impossible task.
I have tried a “go to” function, cross reference list, I've checked if it is written from the HMI. So far no luck and I've ran out of options on how to proceed.
Does any of you have any suggestions what should I try next?
Hello All,
If you cannot find it, how do you know a DB pointer is being used?
Well the problem is such: I can’t find where DB1600.DBX0.4 is written. The cross reference list reveals only where it is read in the program.
When I open the DP1600 it states that the initial value is true and so is the actual value. Is it possible that it is not written anywhere but it takes the initial value to actual value and then just stays true?
Hi all! I'm using a 5069-SERIAL card for the first time, though I have plenty of experience with serial on other AB platforms. I'm running into...
3,833
Hello All, I have been dropped into a hornets nest of a project. The orignal venodor has been kicked off site and I've been hired to complete...
1,846
Hi, I am trying to learn how to use my encoder with my PLC. I recently got a high-speed counter module (H0-CTRIO2) for my DirectLogic05 PLC. I...
2,228
Hi, guys - I've got an odd problem here that I haven't been able to figure out and was hoping someone might have some insight: Background: We...
21
5,951
Morning all. Brand new 820. Out of the box. Apply power. connect Ethernet cable to small 4 port switch, connected to laptop. Set LAN port IP...
7,462
