difficulty in connecting NetLink Pro ETH
kraj
Feb 2010
p
82
hello
problem on Netlink Pro Eth.
i connected the Netlink to Switch and from there to 2 PCs. i am able to get the data on 2 PCs.
Now wants to connect third PC. However as soon as i connects to third PC communication stops on all PCs.;) i am able to to connect to any two PCs at a time.
Please tell 1 Netlink can be connected to how many PCs at a time. I believe it is 4. In that case, i need help to solve above problem.
:geek:
thanks
raj
hello
i use Net Link Pro eth from Softing Ag
product model is netlink pro eth
cpu- 32 bit ricsc, 2mb sram, 2 mb flash
protocol data transfer rate - fdl, max 12 mbits
connection- active line with 9 pin d sub connector and bus termination
eternet interface-
ethernet- 100base-tx/10base-t
connection - rj45
they allow Six PC connection at a time
but i found difficulty in it
as i stated above
What is the manufacturer & model of the Netlink you are using?
Hello, I'm a electrician who is furthering my education and learning to be a programer , I have a Dell laptop running windows 7 with rs logics pro...
22
6,313
Good Afternoon , We had to replace a Powerflex 70 2 HP with a 3 HP. These drives are on Devicenet . Once installed and transferring with...
3,941
Dear All , I am building SCADA solution for HVAC system using Factory Talk View 7, I am using rslogix 5000 to creat the automation program as you...
3,115
This is my first time here and also my first time to work with WAGO..I need help badly...I am stuck with this WAGO Device. I am working with a...
2,507
Hi Guys GOAL: I have HC900 PLC and a CS15 HMI that I need to configure alarms for. The goal is to require the user to acknowledge the alarm...
2,206
