Has anyone had similar issue? I have a digi one iap modbus tcp converter polling abs RTD data from pump controllers. I am new to the issue, but historian shows very spotty data back through 2016.
I've worked with digi ones before with success. I have the config file for this particular device. I can ping it. But I am unable to connect to check settings via the web interface. I also cannot hold a connection to the device IP through a modbus poller tool.
Aside from resetting to defaults. Any ideas on a fix on this or how to connect? Anyone know the default IP address? I've already ordered a replacement but these things are pricey.
Any info is as always appreciated.
Thanks,
Ben.
Thanks,
Ben.
