DIGSI 4.83 with simatic manager v5.5
panthripu
Mar 2004
228
hi
I tried to install DIGSI 4.83 on my laptop which is already having simatic manager v5.3. I could not install it as the set up says that it needs simatic manager v5.4 or more. I upgraded simatic manager to v5.5. Then I installed DIGSI. Now when I open DIGSI it opens simatic manager. I dont know how to open DIGSI ? any idea please?
You just work from simatic manager.
Create project, Click insert new object>SIPROTEC device.
If you accustomed to DIGSI type of view Switch to topological view by clicing View>Topological view.
@goghie- I upgraded simatic manager to v5.5 already and then installed digsi.
@marcius-I will check the way you told and will update you.
Digsi
Hi
I tried after simatic manager is open. I inserted devices and under devices I can seen DIGSI and then siprotec. But when i click , it does not result anything.
Ok, must be a compatibility issue.
I checked the digsi manual and it says you need Step 5.4 for digsi 4.83 and Step 5.5 for digsi 4.84.
Dear All, I am not much friendly with Siemens Packet. I executed check required software package in Simatic Manager & it showed as additionally I...
1,589
Dear Sparkies, I'm trying to install the Simatic manager V 5.5 on a computer that has DIGSI 4.6 installed on it, bt I couldn't. The message I...
3,979
I recently tried to load Step 7 software on the same computor where I have Siemens DIGSI installed. After many un-successful attempts I called...
5,912
We are facing intermittent issue with emergency stop and line stop. Line stop triggering with alarm of line stop push button activated at one...
190
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
107
