Step 7 and Digsi software
cornbread
Feb 2007
madison, indiana
407
I recently tried to load Step 7 software on the same computor where I have Siemens DIGSI installed. After many un-successful attempts I called tech support and they told me un-install the DIGSI and then install Step 7 followed by the DIGSI software. Step 7 installed fine but now I can not install the DIGSI software.
Any help would be greatly appreciated.
Hello cornbread;
My one experience of trying to load both Step 7 and DIGSI on the same computer was very frustrating, and I had to use seperate computers for that project.
However, there are comatibility notes on the DIGSI product information sheets that state that it would be possible, under specific conditions, including the installation of a CFC package and specific versions of Simatic Net in Step 7:
If the automation software STEP7 or SICAM plusTOOLS is used on the same computer,
then the following must apply to the installed versions for compatibility reasons:
Currently:
DIGSI 4.71
SICAM PAS 5.11
SICAM SAS, RTU, eRTU V5.20, V5.30
STEP7 5.30 (with SP2, incl. CFC 6.1 + Hotfix 1, SIMATIC NET V6.3)
This document is located at the following link, if you care to examine it:
http://siemens.siprotec.de/download_neu/software/DIGSI_4/PMS/7XS54_DIGSI471_V1.0_en.pdf
Hope this helps,
Daniel Chartier
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
180
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
251
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
343
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
551
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
686
