DirectLogic 405 PLC Programming
wilvil2000
Dec 2003
New York, USA
I am stuck with a DL405 PLC that I bought from Ebay pretty cheap, I guess, and I need two things; A programming cable and the software. As it turns out, I can afford the cable but the software "Directsoft 32" costs too much for me. I bought the PLC to learn Ladder Logic but I need the software. Does anybody know of an affordable software package that I can use to program this PLC?
Thank you,
Wil
Sorry to say, I think you're stuck. The DL405 needs the 'full' version of DirectSOFT as the 405 is the A-D's high-end PLC. You would have been better off looking for a DL05 or DL105 to play with. As you probably know, you can get DL05/105 specific DirectSOFT for only UD$99. Hopefully, you didn't pay much more than $200 for that 405, because you can buy a DL05 + software for about that same price, NEW, from Automation Direct.
I 'think' the v3.0 demo software (available HERE) will work with the DL405. You can only write small programs, but it IS free.
Keep checking on Ebay. You might be able to find the software there. Just be sure it's 'legitimate', or it won't work.
You can save US$29 and make your own cable. The wiring diagram is HERE.
beerchug
-Eric
Hi there, As part of an upgrade we are ripping out a DL405 PLC with a Visual Basic front end and adding some expansion racks to an existing S7...
3,011
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
833
Is it correct to say that the dl05 program when uploaded does not store the current value in a v memory location? I have a customer that has one...
3,096
Hello everyone, Background: We have a Directlogic 405 PLC that has an output card that has all solenoids on it. These solenoids are on plugs with...
2,895
Can someone please explain the sinking and sourcing with respect to DL405 series PLC? I have already been through the manuals. Explanations with...
1,999
